QUOTE (Tech4all @ Nov 13 2009, 11:23 PM)
I have a PV stuck in the self-test mode; they call it a post. It happened when initializing the start-up configuration as the PV re-wrote the number of posts from 1 to 256 by iitself.... honest. Cycling the power will not work b/c that's when the self-tests start, all over again. Both keyboards, PV terminal and PC w/ Hyperlink, are locked out. Rapidly tapping corners will not fault the PV out b/c the touchscreen test was not seleected at configuration. I suspect I have firmware or memory problems with this PV; I just need to stop this crazy loop. Much thanks.
Try re-flash the firmware.
