Currently I have a SLC5/04 that will be connected to a 1761-NET-ENI/B and there will be a PC at the other end.
Eventually I will replace this SLC5/04 to a SLC5/05 and connect it through a hub. Later on there will be a total of five or six SLC5/05.
My worry is that reading through AB's literature: 1761-UM006E-EN-P august 2005 on page 38, it states that when using the 1761-NET-ENI devices I can only hook up 4 devices. With node 1 to 4.
I understand that...at least I believe I do!
My worry is that if I replace the SLC5/04 to SLC5/05 how many 05 can be on the same network (separate network obviously)? First step would be 5 ovens, there is another one already with a SLC5/05 CPU (this CPU is connected to PC for the HMI using VB6, actually it's on the network where any there computer with VNC can take control of the computer at a distance, this uses a second Ethernet card on the motherboard). I would like to add other machinery to it to be able to monitor the entire activity in the factory.
I know that I have got some other topics about this project. I had many advices and I appreciate it. I have a laptop with RSView software on it with which I can build a HMI for the supervisors. Basically is just to gather a minimum of information on stop times on the production.
Thank you to all of you experts.
