Full Version: RS 485
Forums.MrPLC.com > PLCs and Supporting Devices > Mitsubishi
gixer
Trying to get to number displays working to display the first 3 digits in D1005. Have done it over 20 times with the FX2N-485-BD and never had a problem.
The settings for the display are
Buad rate 1200
8 bits
No parity
1 stop.
I am sending the following, is this correct ?
[mov h359 D8120]
Thanks in advance.
Steve C
Crossbow
I just set it in PLC parameters.
sean_wang
QUOTE (Crossbow @ Nov 11 2009, 12:32 PM) *
I am not make sure ,but you can try this below setting
9600 Buad rate
E parity
7 bits
1 stop
LD M8002
MOV H6086 D8120
LD M8002
MOV K0 D8129
LD M8002
MOV H0 D8121
END
Glumglum
QUOTE (gixer @ Nov 11 2009, 08:39 AM) *
Buad rate 1200
8 bits
No parity
1 stop.
[mov h359 D8120]
Thanks in advance.
Steve C
Hello. I have a sytem i sell to one customer. FX3UC with RS485 BD card. I use GX IEC Developer
I remember the first time i did this i had problems.
I got support through Beijer here in Norway. They found out that i also needed GX Developer installed to get the programming to work the BD module uses a winsoc version from GX Developer.
Not sure all the things they did but now it works every time.
I also got some librarys with ADPRW and MODBUS FX3U Master funktions.
kaare_t
You have the wrong settings for D8120. For your setup you will need:
[MOV H1051 D8120]
LeDude
I just switched from a 485-BD to a 485-ADP, because I need a full-duplex communication.
So I took the BD out and attached the ADP and adjusted a few things - it does not work.
Am I correct that the ADP is still Channel 1, since there is no 485-BD attached to the PLC anymore?
I read the wiring is differently?
But I could not find any difference in the manual?!
Attached is my code...
Help is appreciated.\
Cheers
kaare_t
So now you have:
1x FX3U-CNV-BD
1x FX3U-485-ADP
right?
LeDude
QUOTE (kaare_t @ Dec 2 2009, 10:16 AM) *
So now you have:
1x FX3U-CNV-BD
1x FX3U-485-ADP
right?
Correct
1x FX3U-CNV-BD
1x FX3U-485-ADP
and
1x FX3U-232-ADP
kaare_t
You are correct. You can still use the first ADP card as channel 1 (same as BD), so it should work..... I don't have GX Developer installed on the machine I'm currently on so I can't look at it right now
LeDude
QUOTE (kaare_t @ Dec 2 2009, 09:33 AM) *
OK,
I finally got it working.
I can send commands which proved to work with an IMS Drive.
So now I spent some time with the IMS drive to give me feedback via RS485 (positions).
I was able to read everything out via HyperTerminal, so the drive does send, but I can't see it in the PLC.
Again,
I can send commands to the client.
The client send stuff back, but I can't see it in the PLC.
My settings seem to be right, but I guess somethings fishy with my program.
Does anybody mind to explain me what I screwed up?
I am scanning a register for hex numbers,
which triggers a command.
What I probably did wrong is: I do not read in?! Well, I don't know :D
Thanks a lot!
