I have 3 Ethernet hosts configured but haven't touched their settings today.
However I now run into the following error when I want to run the Test tool, regardless of Offline / Online setting.
Any other projects seem to run fine. Any idea what this error means?
If I select NO, the same error appears with same details. If I select YES the test tool is closed...
Running CXD 3.111 with all latest updates installed.
Edit # 1: I can just confirm I get the same error when running the project in NS-Runtime 1.20 on the same host system. What is going on here
Edit # 2: Same error on another PC system. So this is a project related error.... what is it?
