QUOTE (rcshete @ Nov 10 2009, 12:19 AM)
Hi
We are working on a project where I have to setup ControlNet communications between SLC5/05, PowerMonitor3000 and LSM(1402-LS51), all connected on ControlNet.
Communication of data between SLC & PowerMonitor3000 over ControlNet has been setup. But we are facing problems regarding communicationS from SLC to 1771-ACNR and the LSM module.
Require help on how to setup this communications.
Thanks
No experience with the SLC ControlNet card as a scanner we always used it as a slave with a 1756-cnb as the master. I still would think that RSNetworx would schedule the Data of the 1771-ACNR and the LSM to memory locations in your SLC scanner. Then it is a matter of transferring that data from Scanner Memory to PLC Memory {M register manipulations are coming to mind here}.
