Thanks for the reply lostcontrol.
I got the example from W462-E1-02, CP1L operation manual.
The physical set-up is as follows:
0.00 - N/O aux from e-stop.
0.01 - N/O push button, for now being used to initiate the origin search.
0.02 - N/O push button, for now being used to initiate a fixed distance move.
0.06 - Z signal from drive.
0.10 - N/O home position sensor on axis.
All above confirmed working (except 0.06 which shouldn't stop it moving as it showing as off when monitored)
100.00 CW pulse to drive.
100.01 CCW pulse to drive.
100.02 Run signal to drive
100.03 Alarm reset signal to drive
100.04 Deviation counter reset to drive.
I've attached the program and the pages from the manual with the example I'm using.
When the Estop is enabled (0.00), the drive powers up and holds position.
When 0.02 is pressed, it works fine and the axis moves by the set number of pulses.
When 0.01 is pressed it just sits there and does nothing, nothing is showing on the outputs either.
Actually, In writing this, I've just realised that I haven't actually tested a CCW movement yet so that'll be the next thing I do when I get back to this tomorrow.
Thanks in advance to anyone with any suggestions :)
Click to view attachmentClick to view attachment
