Full Version: PLC programming
Forums.MrPLC.com > PLCs and Supporting Devices > GE
khmerplc
Hi,
Can I program the PLC with the hand held programmer or do I need a software like logic master?
GE Fanuc PLC Hand Held Programmer
IC693PWR321 power supply rack 0
IC693CPU331-BB CPU module, slot 1
IC693CMM311N communications control module, slot 2
IC693ALG221E input Analog, 4 current, slot 3
IC693ALG221E input Analog, 4 current, slot 4
IC693ALG221C input Analog, 4 current, slot 5
Intellution FIXMMI 6.0 software. Can I use this to programm the PLC?
thanks.
Steve Bailey
It is possible to program the PLC using the handheld, but it's not easy to debug once you've programmed it. Furthermore, you can not upload or download a program file created with Logicmaster (or any other programming software) with the handheld. There is a memory card that fits in the handheld for program backup and transfer, but the handheld is the only device that can use it.
Intellution software can not be used to program the PLC.
