QUOTE (Jon W @ Nov 2 2009, 11:20 AM)
Sorry the problem was that when I attached the 1784-U2DHP to the SLC-5/04 and the configured driver for this interface was still running I could not get connected, but if I disconnected the 1784-U2DHP, stopped the driver from RSLINX, then reattached the cable and then restarted the driver from RSLINX I could then browse and connect to the PLC. The Data rates were not an issue as they did match between the connector and the PLC. I was just wondering if this was SOP for these units or did I miss something during the driver configuration. Also on this PLC I have to have my station number set for decimal 50? I have some knowledge of AB plc's and drivers, though most of it is with SLC-5/05's and ethernet.
Thanks for the reply.
I have a similar issue with mine in that if RSLinx is running and I then connect the USB end, I have to stop and start RSLinx or it will never browse. My case is a little different and I never went from PLC to PLC (mine are PLC5 anyway) with the laptop running so I cant verify the problem you have with the other end of the cable, but I would sure think its just something we have to live with.
Here's hoping I'm wrong...
