Full Version: GOT1000 problem
Forums.MrPLC.com > PLCs and Supporting Devices > Mitsubishi
hosam
hi all
i have aproblem with GOT1000 hmi its touch pannel does not work properly and it is password protected so i called the supplier to give me the password or the HMI program but he told me that his computer is damaged and all data were lost the plc also is password protected i can not make the program from zero is there any body can help me?
thanks
LeDude
See if the GOT resets by removing the battery.
Crossbow
Send the unit in to Mitsubishi for repair. Maybe they can repair it without you having to replace or reload the program.
An OEM who password protects their projects and doesn't bother to document that is pathetic. Who cares if the projects were lost on the PC, they can be uploaded provided they documented the passwords. They should have the passwords written down somewhere to go with the machine drawings and such. I doubt they didn't keep a copy of the drawings or some paperwork for the panels.
hosam
hi all
the HMI does not have any battary.what shall i do?
hosam
QUOTE (Crossbow @ Oct 28 2009, 08:48 PM) *
also we do not have the wiring of the machine and when i asked them for it they said the same words. the computer was damaged.Is there any other solutions except rebuiding the project?
Inntele
QUOTE (hosam @ Oct 29 2009, 05:00 PM) *
Hi,
Unfortunately, the technical answer to your question is impossible to give.
There are two options:
1) Require the provision of necessary documentation through court
2) To order a design of new programs then to claim damages in court
gixer
Hi Hosam,
I had a similar problem on an Fx2n that was password protected. There is a way you can "crack" the password and download the plc program. I don't know how legal it is and as such would not describe it on the forum. Im sure if you did a bit of searching on the net you will find out how to do it. It is fairly easy to do. As for the HMI, sorry I've never had to get past the password.
Good luck.
Steve
hosam
thank you Steve.i know this way for cracking but it used only mitsubishi plc not with mitsubishi HMI i tried it with mitsubishi hmi but i failed have you tried it with mitsubishi hmi ?
gixer
QUOTE (hosam @ Nov 8 2009, 08:45 PM) *
Sorry have never needed to. But it is easy to reset and erase all memory using the dip switches on the back.
