Full Version: ML 1400 I/O addressing
brinkmann
This is the first ML1400 (1766-L32BWA) we have used. I understand it has 32 embedded I/O. (20 in/12 out) . I understand the outputs, O:0.0, O:0.1, O:0.2, etc. With the inputs since I have 20, what do I do after I:0.15? I thought 15 was the highest you could go. What do I call the last 4 inputs?
Thanks in advance!
Mickey
QUOTE (brinkmann @ Oct 27 2009, 04:34 PM) *
Thanks in advance!
How its displayed depends on how you configure the display properties.
If the I/O Bit Display Mode is:
Slot/Bit then I:0/0 to I:0/19 will be the input addresses
Slot.Word/Bit then I.0.0/0 to I.0.1/3 will be the input addresses.
Edited per b_carlton's corrected post.
b_carlton
Actually the first 16 can be addressed as I:0/0 - I:0/15 or in the more proper way I:0.0/0 - I:0.0/15
The last 4 can also be addressed in two ways: I:0/16 - I:0/19 or as I:0.1/0 - I:0.1/3
Either are valid. One emphasizes the bit count from the start of the area. The other emphasizes the word and the bit within the word.
You can set RSLogix 500 to display these address references either way. With a project open and a ladder selected go to View - Properties. Choose the Address Display tab. Ffor I/O bits you can choose to have them displayed in the Slot/Bit (First Method) or Slot.Word/Bit (Second Method) [Edit - as Mickey has so quickly shown]
brinkmann
I understand the display modes. I didn't know if I:0/16 thru I:0/19 were valid addresses. Thanks to both!
Invision Power Board © 2001-2009 Invision Power Services, Inc.
