Full Version: Programming the CP1L through a CP1W-ETN01-US
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-One
TheDr
Does anyone know what the oldest version of CX Programmer you can use to program the CP1L through the CP1W-ETN01-US?
My customer is using CX Programmer V7.3 which has the CP1L but no option to connect over ethernet.
I am running CX Programmer 8.2 and there is an option for ethernet.
My customer does not want to upgrade to CX ONE V3 yet unless he absolutely has to.
I see in the manual for the ETN01 that it specifies CX Programmer 8.0 to do this, but wondered if anyone knows of a work around to get this to work with 7.3.
Thanks for your help.
TheDr
Sorry I posted this in the wrong forum. It should have been in the CX Programmer forum and not CX ONE. I don't seem to be able to move it.
PdL
QUOTE (TheDr @ Oct 27 2009, 01:40 PM) *
I am not sure but at least you need an updated CPS file (Component Profile Sheet) for the CP1L CPU series and I think you also need the updated CX-Server files.
If it was just an I/O module you could try to just manually copy the CPS files from a new installation but as this also involves an updated communications path to the CPU I think this will not work, and you cannot update CX-Server manually by just copying some files.
The following procedure is own your own risk. No succes guaranteed and make sure you can roll back if it fails as I cannot predict how CXP will behave.
Attached are the latest CPS files for CP1L series from a CXP8.2 install. You can try to extract the files and put them in C:\Program Files\Common Files\Omron\Profiles\CPSFiles. Overwrite if prompted.
Like I said, little chance it will work but worth a shot. However Omron will not support an installation that has been messed with so keep this in mind...
