Full Version: T flip-flop
Pulsar2003
This is a copy or so of a topic I wrote on Modicon page.
I need to modify a machine that we mass produce. For one it's reduce the wiring time and material coasts. We want to replace a timer in a circuit and have the programable relay to control the entire system.
We'll be using one similar to a PICO
Currently, there is a momentary push button Start/Stop that turns on a pump. It'll go for 30 minutes if it's not shutdown. And if the Start/Stop button is pressed again it will shut off the pump before the 30 minutes are over.
I have no problems with the entire ladder. I tried to remember the logic of a flip-flop, I made a few attempts in a ladder logic but failed.
To resume: On momentary button to start or stop a 30 minute timer.
Any Ideas?
panic mode
you are on a right track, just search forum or download section for "flip-flop"
Ken Moore
Post what you have so far, which brand of relay?
BobLfoot
QUOTE (Pulsar2003 @ Oct 12 2009, 09:53 PM) *
Any Ideas?
Four Rungs of Ladder
XIC I:0.0/0 XIO B3:0/1 BST XIO O:0.0/0 OTL B3:0/0 NXB XIC O:0.0/0 OTU B3:0/0 NXB OTL B3:0/1 BND
XIO I:0.0/0 OTU B3:0/1
XIC B3:0/0 BST OTE O:0.0/0 NXB TON T4:0 1.0 1800 0 BND
XIC T4:0/DN OTU B3:0/0
Will Work for micro 1000 probably adapt to PICO.
Pulsar2003
It is a Zelio from Schneider.
Model: SR2 D101FU
Six inputs and 4 outputs.
Pulsar2003
I found a forum with a flip-flop copied and pasted from RSLogix in ASCII.
I copied and pasted it to my RSLogix.
Next I renamed the inputs, outputs, markers and timer to match ZelioSoft 2.
Next I simply created the ladder.
Unfortunately it still doesn't work. I double checked my own ladder and I didn't mess this one up. I also changed the types of times.
Because this type of relay only allows only on set and reset per markers I only had to make an extra one.
I'll I have to do now to help others is to find out how to get a copy of my screen shot.
Thanks allot.
Alaric
IIRC, this kind of programmable relay scans differently than a PLC does. It scans vertically, solving everything in column 1 of the entire ladder first, then returning to the top of the ladder and solving everything in column 2. Keep that in mind as you review your program.
Pulsar2003
I will.
Mickey
QUOTE (Pulsar2003 @ Oct 29 2009, 07:09 PM) *
I will.
Not at all, Modicon scans that way as does Control Microsystems PLC's (SCADAPacks).
Invision Power Board © 2001-2009 Invision Power Services, Inc.
