Hello,
I have to modify a machine. I have to replace a timer set on or off with only one input.
Now I want to use a Zelio SR2 D101FU to do the job. This will allow us to eliminate lots of wiring.
When I press the Start/Stop it should set the timer to keep an output on for 30 minutes. If I need to I press again the Start/Stop button an this causes the timer to be reset and the output goes off.
I've tried to remember the 2 NAND and NOR circuit....years have passed. And I also tried to make it with the ZelioSoft2. I've failled. And I'm running out of inspiration.
Any body has tips?
