QUOTE (zeratul @ Oct 6 2009, 03:22 PM)
Yes It does.. I got confused because it didn't have the yellow triangle in the symatic manager. Tt sucks man, I am not used to using blocks with understanding them 100 %. This kinda reminds me of PILZ.
Thanks for you reply though
Lets get this clear, is it a standard Siemens Block?
I'm not sure I've heard of a Siemens FB10, but there maybe. Usually the Siemens standards are SFC or SFB type block's, there are some FB ones though, I'm sure.
Any Siemens standard block will be protected, as they protect their code , they do supply block descriptions to inform you how the code works.
If it is not a Siemens block, but a third party block (more likely), then it appears the they have decided that no-one should look at their code.
For info, you can do similar things with ControlLogix routines.
