Full Version: TSX3721 communication problem
Forums.MrPLC.com > PLCs and Supporting Devices > Modicon
zolti103
Hello, Dear
i have a telemechanique PLC TSX 3721 series i wants to upload program from it, i have PL7PRO v 4.5, software, unitelway drivers 1.6, and a USB cable USB-TSXPCX3030(new OEM version not the orignal one, toggle switch at RX position), i have installed all the software properly i connect cables 1 end to PC USB port and other to PLC TER port, as the cable is detected on com3 i edit the com address in schenider driver manager in unitelway configuration to COM3, by default baud rate 9600(aslo tried on 19200), parity odd (also tried none), 1stop bit, 8 data bits , link type=unitelway, force virtual com port enable(also tried disable ), then i go to xway test, here remote address=0.254.0(by default) then i click 'connect' the status shows 'connecting' never shows 'connected' some times computer gets hang. i have tried this procedure on 2 same model CPU, 1 brand new without program, without memory card and battery, RUN indication OFF, battery indication ON, ERROR indication ON and TER indication is blinking, and other CPU is old one (with program )showing RUN indication ON, ERROR=OFF, BAT= ON, TER= slightly blinking.
please help me for getting CONNECTED with CPU, if u suggest for conflict in OS version of part then i think after getting connected with cpu i can upgrade or downgrade the OS version using OS-Loader utility..
please get me out of this trouble
I will remain thank Full to you.
Regards with Great Anticipation
cHud
what os are you using on your computer?
Henrique
Check your system OS. You should not use Vista with PL7 PRO.
Also, in the Drivers Manager, increase the value for Link Time Out and RX/TX Delay for the UnitelWay driver (When I use USB cables, I put these values in 2 or 3). The path is Drivers Manager, UnitelWay Driver, Configuration, Edit..., Advanced Tab.
aggattapauer
You have to install the driver for USB-TSXPCX3030
here
zolti103
QUOTE (Henrique @ Oct 2 2009, 07:42 AM) *
thanks for reply and sorry for my very late reply actually i was out of station..
my OS is winXP SP2 as i have told that i have been tried different values for each function please tell me the exact values for each function i must have to put for the successful connection.. is battery or memory card must required for it ??
Best Regards with Great Anticipation
aggattapauer
Have you installed the driver for USB-TSXPCX3030?
zolti103
QUOTE (aggattapauer @ Oct 7 2009, 05:18 AM) *
yes i have been installed the drivers
Driver Manager version = 2.5 IE18
Unitel way version = 1.6 IE16
the cable is successfully detected in Driver manger of windows XP at COM3 PORT...all information is in my first thread to this topic
regards
aggattapauer
QUOTE
Those drivers are the default drivers, I want to be sure the TSXPCX3030 device driver is correctly installed on your PC: can you check on Installation Application of your Windows if "TSXPCX3030 device driver" is installed??
Otherwise you could install this
zolti103
QUOTE (aggattapauer @ Oct 8 2009, 02:19 AM) *
QUOTE
Hello,
'TSXPCX3030 device driver' is listed in 'ADD/REMOVE PROGRAM' tool of windows in control panel
my OS is winXP SP2 as i have told that i have been tried different values for each function(i.e baud rate, parity, remote address, unitelway slave address,delay values........ etc) please tell me the exact values for each function i must have to put for the successful connection.. is battery or memory card must required for it ?? and what should be the status of PLC for communication to the PLC
mouni
QUOTE (zolti103 @ Oct 9 2009, 05:02 AM) *
QUOTE
Hello,
salut
essay de mettre le couvercle de la carte mémoire pour éliminer le voyant Ter
mouni
tu as quoi comme châssis de base?
zolti103
QUOTE (mouni @ Oct 13 2009, 12:15 PM) *
thanks for reply, but i cant understand your message
i can only understand english
regards
mouni
QUOTE (mouni @ Oct 13 2009, 06:15 PM) *
salut
What you like basic chassis?
mouni
QUOTE (mouni @ Oct 15 2009, 06:27 PM) *
salut
if you have an expandable chassis, you must put the terminating resistor
zolti103
i have CPU all the IOs are inserted no more IOs can be inserted and TER is directly conected to interface ADAPTER cable,
can you please tell what exactly should i put in following fields of unitelway driver configuration fields, if you have any document regarding all the details of 'unitelway driver' and 'xway test'
and in which mode PLC should be for successful communication with PC (RUN, STOP, DIAGNOSE) cpu only has 1 button for diagnose mode
Thanks with anticipation
Crossbow
You should be able to communicate with the CPU regardless of which mode it is in.
The default port settings should work unless someone changed them in the PLC, and then there's no way to tell other than try all combinations.
