Here is what I am trying to do:
I am trying to connect a CPX772 to wonderware through serial port 1 through GESNP (on the wonderware side). I have configured all places to setup the serial ports on the pc to match the configuration on the plc.
I am able to connect to the plc with LM90, but I am unable to connect with GESNP.
The cable pinout I am using is IC693CBL316A. It has a DB9 on the pc end and an RJ11 on the plc.
Does anyone have any idea as to why this doesn't work?
A little side note:
I am not going to upgrade away from LM90, this system will not be there that long anyway.
This system communicates TCP primary, this is for a backup in case of a network failure.
