I'm not very familiar with the Telemecanique line of products and prefer to get answers from these boards because of the level of expertise.
I'm integrating a new robot loaded CNC machine (OP53) between two other machines (OP50 & OP60) connected via a conveyor. I need to do some handshaking signals with OP50 & OP60 and because my cell controller can only talk Profibus with the CNC machine, I was hoping to extend the Profibus network to the exiting machines.
The cell controller will be a TSX Premium, probably a TSXP572623M processor and I'll have a TSXPBY100 module in the rack.
Each machine has a TSX P57 202M processor mounted in a TSX RKY 12EX rack with one available slot. I want to add a TSXPBY100 module to each.
So I guess my questions are:
Will the existing cells using the current processors support the Profibus module? I assume so because I was able to add the module in the h/w configuration (PL7 Pro v4.5) but I hate to assume.
Can the TSXPBY100s work in a slave mode (not sure that is the correct term) or do I need a DP/DP coupler with each?
Thanks in advance.
