Full Version: cpu 315-2dp
Forums.MrPLC.com > PLCs and Supporting Devices > Siemens
indepthmarine
I am trying to add 4 analog inputs to a cramped system.
power supply
CPU315-2DP
DI 16
DI 16
AI 8x 12bit
AI 8x 12 bit
CP 340rs232C
CP 340rs232C
CP 340rs232C
CP 341rs232C
The HW config screen in S7 shows slot 3 as empty. I can only drag modules into slot 4 through 11, which are all full.
I hope to be able to add another AI8x 12 bit module, but dont think I can.
Alternatively, I must change some RTD inputs into 2 wire 4-20mA inputs and use the spare inputs for my pressure transducers. The second AI 8pt unit has 4 RTDs right now. I want 4 RTDs and 4 pressure transducers.
I have M-systems signal conditioner to change the 4 wire RTD into a 4-20mA, so I think it is possible, but am not used to S7 at all...mainly use Omron CX-One
Is it possible to add another SM331 Analog input module to such a system?
Thanks
dsc
Slot 3 only can be use with IM360 card. Why not u change that 16 DI to 32 DI card and can save one slot.
If not then need to extent another rack by using IM360.
indepthmarine
QUOTE (dsc @ Sep 8 2009, 09:40 PM) *
Thanks DSC.
Would do...but am offshore Spain, no access to new modules. Trying to familiarize with S7 and change 4 RTD inputs into 4 RTD + 4 analaog 4-20mA
Think I have it figured...just have to be careful in the logic not to destroy what already works.
will be back with more questions undoubtedly.
Firstly:
on SM331 AI 8X 12bit, there are the inserts. Currently they were all set to A for RTD.
I am moving 2 of them to D for 2 wire analog current.
Is there also a software setting I need to adjust to accomodate this change, or is it simply the jumper block?
