sandman
Aug 23 2009, 11:05 PM
Hi guys we are using a siemaens s7 unit in a sand plant and the PC that we are using is gettting long in the tooth and needs replacing the PC has a card with these details "CP5613" and C79039-a8000-z077-02-sa we desperatly meed to find a driver for this card so we can upgrade the PC any help would be appreciated
Sandman
JesperMP
Aug 24 2009, 06:18 AM
Hi sandman.
What is the software that is running on the PC ?
If it is some Siemens software, such as Protool RT, WinCC or WinCC Flexible, then the necessary drivers usually comes included.
It is also possible that the communication software called Simatic Net is used. This software may be used with the previously mentioned softwares, and also with other 3rd party software (Citect f.ex.).
If Simatic Net is used, then it is probably a version for the CP5613 card, i.e. Simatic Net CP5613 or something like that.
Go to the Windows Start menu .. SIMATIC .. Information .. Installed Software. Use this to list all the Siemens software on the PC, then post that here.
Btw. Are you possibly working in a foundry ?
