I did a quick search and didn't see what I was looking for, so here goes. I suppose this might fall into the "other PLC" category, but please bear with me for the Modicon tie-in...
We inherited a system with Motorola MOSCAD and ACE3600 RTUs, both of which convert their native MDLC protocol to Modbus at a communication port. We need to hook up some simple Maple Silver series (HMI520T) 6" operator displays for basic discrete and analog status displays. I don't know if the addressing is strictly MOSCAD related, or if it's generic to any Modbus protocol. A conversion formula is used to convert MOSCAD table/column/row to Modbus address:
Modbus = (Table * 2048) + (Column * 256) + Row + 1
I realize that this formula is for relative addressing, and that for absolute 5-digits we'd probably need to add 30,000 (or 40,000?).
I noticed on the Maple product, they only support Moscad tables 0 through 4. If my integer values are stored in Table 1, then the converted Modbus address is typically 20xx (for example 2045). However on the Maple display, for analog/integer values, the addressing formats are typically "3x" and "4x", which I think refer to 30,000 addresses for analog inputs, and 40,000 addresses for holding registers. Other listed formats include LW, RWI, RW, Ms_RW or Ms_LW. Any advice on which is intended to match our 20xx address?
Also - we're using some Table 1 words to transfer blocks of discretes. So the address would still be 20xx, but with a decimal or colon used to denote individual bits (for example, 2044.3). The Maple software's discrete graphic dialog box suggests data formats LB, 1x, 0x, RBI, RB, Ms_RB, Ms_LB. Any advice on which would match our intended use?
Perhaps this question is too specific to the Maple units, in which case I wouldn't mind a referral to another forum where folks might know the product. I called Maple tech support and the guy said he didn't know a thing about MOSCAD or Modicon addressing and to just read the manual (and get off the phone).
Thanks...
