Full Version: Compact Logix
aarotech
Programing with the RSlogix 5000 but need any device to interface with J1939 so I can control and recieve info from CAT engines.
Any help or recomendations would be appreciated .
Ken Roach
The approach you take may depend on which other networks you are using; If you're using DeviceNet, look for a DNet/J1939 gateway.
The J1939 interface I hear about most frequently is the Anybus-X from HMS Fieldbus (www.anybus.com).
aarotech
Just Compact logix controller with Ethernet.
Arun Opto 22
QUOTE (aarotech @ Aug 17 2009, 08:30 AM) *
You may want to contact a company called Monico, in Texas. http://www.monicoinc.com. Person to talk to is Doyle Taylor. Monico is in the business of devices that interface control systems to CAT engines, and I know we had discussed J1939 back in 2007. They may have implemented that into the Opto SNAP-PAC-S1. If so, you're in luck on the A-B side, as that can share data over EtherNet/IP with ControlLogix.
