QUOTE (EasyButton @ Aug 14 2009, 02:15 PM)
Pdl,
I was able to do this by using the exact same name on the PDF file as the CXF file and saving the PDF in the same folder as the CXF! Pretty Cool!
Strange, I thought I'd try this but I will have to double check.... still it would be nice if CXP could produce some kind of template file similar to the CX-One library FB but with the user variable input/output names included.
QUOTE (dweste @ Aug 26 2009, 07:51 AM)
You can even point CX to your own function block folder under 'Tools->Options->General->FB library storage folder', so you can make your own FB library, with PDF documentation
Nice tip, be sure to check this one out. Thanks!
