Hi,
I'm trying to send SMS using CJ1M and DIGICOM POKET GSM modem via the RS232 port integrated on CP21. I've copied a working program for sending SMS using a CP1L and Siemens MC35i, but now, after sending the AT command using TXD, the Reception Completed Flag (A392.06) doesn't go ON, so I can't know if the message was correctly sent.
The cable i'm using is the same I've used for CP1L and MC35i:
Modem | PLC Omron
Pin 2 -> Pin 3
Pin 3 -> Pin 2
Pin 5 -> Pin 9
| Pin 4 (PLC) - Pin 5 (PLC)
I suppose there is a problem into the cable, but I can't find any configuration schema for it.
