Hi,
Thank you very much for the in-depth information, but just looking at the cabling information in the LK202 manual it looks another device required between the LK202 and PC?. I have trawled the web but can only see cable pin outs for LK202 to various devices e.g. NT touch screen display but not direct to PC
Is it possible to connect direct between LK202 & PC.
Regards, Brian.
QUOTE (bluebyu @ Jul 28 2009, 05:15 AM)
Welcome to the board.
Yes you can use the LK202, but it is RS422. An LK201 is RS232, and would directly connect to your PC.
Manual for the host link unit can be found here;
http://forums.mrplc.com/index.php?autocom=...mp;showfile=368Cable diagrams can be found here;
http://forums.mrplc.com/index.php?autocom=...amp;showfile=74Do you have the manuals for the C200H? It can be found here also;
http://forums.mrplc.com/index.php?autocom=...mp;showfile=506http://forums.mrplc.com/index.php?autocom=...mp;showfile=505You may want to consider upgrading at least to a C200H Alpha, these have a separate power supply. You would have to change the rack, but, the I/O cards will still work.
Hope this helps.
