QUOTE (ElecPneuGuy @ Jul 18 2009, 03:30 PM)
Use the safety relay to shut down the output power to your motor contactor. You could wire in the contactor to your safety relay so that you can't reset the relay if the contactor is pulled in.
This doesn't work. You've got to provide safety rated control throughout the system. The non-safety contactor attached to a safety relay doesn't cut it.
If you can't do it with a 700S relay, then you need something much bigger.
I can only think of three alternatives. With drives (and presumably soft starts), you can disable power to the IGBT's which disables power to the motor in a solid state "contactor". That is the purpose of the "safe off" or "safe torque" off connection. Several drives including some of the Powerflex drives have this set of contacts which can be driven from a safety relay. This includes the 40P, 70, and 700S. I believe you can get it on some of the Kinetics drives as well. This sounds expensive but at the lower end of the power spectrum (<10-15 HP), drives tend to actually be less expensive than starters in many cases. You may want to check other manufacturers, too, as they may offer alternatives that Rockwell doesn't.
Second, Rockwell sells a device (forgot the exact name) which is essentially a big safety rated contactor to kill power in an area plus it has options to disable hydraulic and pneumatic power as well. It's called "Electroguard". It's not cheap but it performs the function quite well.
Finally, the only other choice is to work with a fail-safe brake or clutch that allows you to forcibly stop a shaft from turning. Normally the clutch/brake just sits there innocently doing nothing so it won't be "wearing out" any time soon. Whenever the system calls for it though, the brake/clutch disconnects mechanical power.
