Not Sure What I Have Missed Or Need To Check Next,
SLC5 Driver Request Timming Out On Node-2 [HMI]
Listed Below Are The Findings/Results: 07.16.2009
PLC Processor AB SLC5/03
Interact Power Station PS10 HMI
SLC5 Driver Error Codes [Offline/Online/Program/Run Modes] Interact Application Mgr.
Interact Shell Was Set@ Com-1/Now Com-2, Interupt&Irq Default
Recheck CH-1 RJ45/Cat To CTC Com-2 9-Pin D-Shell Cable. /Ohm'd-OK
[No CTC Driver Code 10 Generated/Cable Is Open:]
Note: Previous Comm Cabling For PLC CH-1 Works w/
AB 1747-PIC [DH485] To Laptop Com-1
Currently Using PLC CH-0 9-Pin D-Shell RS232/DF1
For Laptop Comm/Working
LISTED DRIVER ERROR's [Interact AM [Application Mgr]]
1st Time:
00:10:41 Driver 4H Write Overflow [2] [FIXED, Increased Buffer From 10-20]
00:08:13 Driver 8H Request Timeout [2]
00:07:09 Driver 5H Node Inactive [1] [PLC Processor CH-1 DH485 To CTC PS10]
00:06:42 Driver 5H Node Inactive [0] [PC To PLC Processor [Working Communications]]
2nd Time:
Driver 8H Request Timeout [2] [CTC Station ID=2 / Node-2]
RSLOGIX-500 S:9&10 Not Set [0's] [Interact HMI Comm Status] Will Not Show In RSLINX [Normal]
PLC Processor DH485 LED Status=Blinking Green
CTC Station ID=2 [Node-2] Max Nodes=2
COM-2 RS485 [Jumpers Verified] 9600 Baud
PLC5/03 CH-1 DH485 9600 Baud, Node-1
[CH-1 Works w/1747-PIC Converter To Laptop]
CTC AM [Application Mgr/Supervisor
SLC5 Driver Listed
SLC5 Driver File's Info:
SLC5.DLL 49KB Application 10/29/1997 3:05 PM
SLC5.EXP 78KB EXP FILE 4/23/1999 1:08 PM
SLC5.FIL 1KB FIL FILE 2/17/1996 11:29 AM
SLC5.TXT 4KB Text Doc 4/23/1999 1:07 PM
CTC Tag Editor Addressing Description Format: SLC5\2$B3:0,0 [Interact Replaces "/" With ","
SLC5 [Driver]\ [Delimter] 2 [Node]$ [delimter, seperates Station# From File Type] PLC Bit
Thank's For Your Time/Help
Jeff Drescher
