QUOTE (BobLfoot @ Jul 15 2009, 10:16 PM)
So to use less energy and fewer bulbs were willing to pollute with Mercury and Phosphorus.
Am I wacked in what I see?
No. It's a case of the greens going nuts over something they don't understand. By forcing the utility industry off coal and especially nuclear and into natural gas more and more, we are forcing more and more energy-intensive manufacturing overseas where cheap 3.5 cent/kwhr coal electricity is being produced. The end result is that we pay higher utility bills in the U.S., supplement the incomes of people living in less energy efficient and far more polluting countries, and increase the global pollution that we are supposedly trying to prevent. Fluorescent bulbs definitely have their place, and they make economic sense. That's why legislating them is just plain silly. People are going to continue to use them because they save money in the long run and because they are more convenient, regardless of what any legislators do. The mistake is with government getting involved. If you call the EPA offices and ask about clean up procedures, you will quickly find out just how stupid they are because you effectively need a huge environmental remediation company to come to your house with the space suits and do a full dress down of the place if you believe what they are telling you and you ever break a bulb.
Phosphorous is toxic but it's like sodium...once it reacts, it is harmless. Phosphorous is one of the 3 major nutrients for plants. The biggest problem with "phosphorous pollution" is with overfertilizing lawns...the excess fertilizer gets into bodies of water (rain water runoff) and causes massive plant growth (algae blooms) in the water. The place I work for now doesn't make phosphors but we definitely making the starting material (phosphoric acid).
Mercury is definitely toxic all the way around. It is not so bad in it's normal liquid state...the vapor pressure is so different that you have to heat it to get it to vaporize. It's in that form that humans readily absorb it. In the normal liquid state you can't absorb it through your skin for instance (very high surface tension as well). The amount used in a discharge-type bulb is very small. It just has to vaporize a very tiny amount and just like copper, the volume that mercury takes up in gaseous form at a little over 1 atmosphere is astounding compared to the space it takes up as a liquid/solid. There is also a lot more mercury in metal-halide fixtures, enough that you can actually see the mercury pool in the bulb while it is still igniting (very hard to see once it is lit of course).
There is a mercury mine in Spain or Portugal I believe (forgot exactly where) where you can literally see the mercury "sweating" down the walls. It is harmless but very impressive to see. Also, mercury readily amalgamates (liquid dissolving into a solid) with gold. Even today with mercury amalgamation no longer in use for mining gold, most gold still has traces of mercury in it. You are much more likely to get a small amount of mercury in you from wearing gold jewelry than cleaning up the mess if a fluorescent bulb ruptures on you.
Focus on the important part...the life span. If you use 100 W incandescent bulbs, you usually end up changing them about once a year or every 3 months if they are in continuous or nearly continuous application. With the fluorescent it will be years before you do so. At least in an industrial/commercial setting, the labor savings ALONE more than justifies their use since the cost of the bulbs is almost inconsequential compared to electrician labor rates to go around changing light bulbs. I've even gone to changing all panel bulbs out for LED. It's only in the last year or two that LED bulbs are now in the running with fluorescent in terms of usable lumens per watt of light (high pressure sodium is still king, but that usability factor makes it much less attractive). But I've been installing LED pilot lights for a long time purely because they cost so much less to maintain (change bulbs once every 10-20 years).
