QUOTE
[it seems that your major question right now is about the "Input Max" setting on the SCP ... we can't tell whether this is "right" for your system without knowing more about how everything is set up – but here's something that MIGHT be helpful ... the "Input Max" setting does NOT (I repeat: does NOT) mean the "highest/maximum input signal that should ever come in" ... instead it just helps set up a ratio between the INPUT signal and the SCALED signal ... specifically, you don't have to use the MAX/HIGHEST value for the input signal – you just need a value that CORRESPONDS with whatever value that you enter for the "Scaled Max" setting ...
more specifically, the SC does NOT perform any type of "limiting" function ... in other words, if the actual input signal happens to go higher than the "Input Max" value that you entered, then the output value will simply GO HIGHER than whatever "Scaled Max" setting you entered ...
so ... it's entirely possible that the numbers you've reported are OK for your system – just as long as the "Input Max" entry correctly corresponds with the "Scaled Max" entry - and likewise, that the "Input Min" entry correctly corresponds with the "Scaled Min" entry ...
Thanks for the info, I just have a couple of years of night classes under my belt which means I prob ally have less than a year in school, so I appreciate the help, Lord knows I need it. Though I dont have that much school under my belt, I have alot of experience in this field and took up with the programming part pretty quickly. I hac to leave school when I had a job offer I couldn't refuse with an engineering company which did programming and specialized in Rockwell software. The only thing is when I got there their main client had switched the whole plant to Siemens, and Siemens had a 5 year maintenance contract with the plant. So I didn't get to further my education in Rockwell software. I left school right when I was getting into analog programming, so I'm lost in this subject. I worked with a Instrumentation company for 15 years so I know all about analog signal and calibrating and all that but just haven't had no experience in analog programming. As far a descrete programming I feel pretty comfortable in that. I had PLC's set up at my home and when I was in school thats all I did for the two years, so much that the students that where way ahead of me in class came to me when the instructor, who was a very good and knowledgeable teacher, was busy with someone else. I know I have alot to learn and I'm planning on getting back in school, but right now as soon a my clients find out I have PLC programming experience, and I tell them to what limits my experience is, the have something for me to do. As far as adding a motor, limit switch, or something to that nature I feel OK, I also have a friend thats wanting to partner up with me that is a very experienced programmer and I alway go to him if I get in to far over my head. I know my limits and would never attempt something outside them, I'm always honest and up front with clients about my programming experience.
QUOTE
incidentally, if you're interested, you can find a lot more about "scaling" by downloading the "Scaling with y=mx+b" material from the Sample Lessons page on my website ... it's in two parts so download them both ...
Thanks, I'm familiar with you and your site is in my favorite list. I've been coming to this forum and reading post for years. I'll check them out.
QUOTE
as far as the "rung comments" issue, you might want to take a look under "View / Properties / Comment Display" from the RSLogix500 main menu and make sure that the "Rung Comments" feature is turned on ... some people turn it off to save room on the screen ... years ago I actually drove 120 miles (one way) to help a new programmer debug a piece of used equipment that his company had just bought ... when I got there he was fussing and fuming because there weren't any rung comments in the existing program ... he went ballistic when I clicked the magic spot and the comments popped up all over the screen
I have the program saved on my laptop, I opened it up and I clicked view and it didn't give a properties option.?? Maybe I need to be on line with the processor?
