Hi guys.
I was in Tanzanioa till a fortnight ago. There I did a job using Premium + SCP-114 as a Modbus(RS-485)master to pull in data from 12 VFDs. The communication was done using the READ_Var function block and the RS-485 bus worked perfectly provided all slaves were energised and online. The responses to writing/reading about 12 words of data from any slave was less than 1 sec.
However....., when as single drive was powered down, what I noticed was the communication times drastically deteriorated, sometimes taking as much as 15-20 seconds for the changed data (typically motor speed, current etc) to appear in the PLC.
I tried many things to improve the performance, such as blocking read on all slaves when it was needed to write a value in a slave, also I tried various scheduling times for sending the read_var to each slave.. I'll appreciate If any one of you goes through the scheme I've attached. To see it you'll need Unity Pro ver.4.0. It is a FBD diagram and can be seen to make sense easily. I'll welcome all comments.
A million thanks up front, and with best wishes for your success...
Raj S. Iyer
