QUOTE (mckeand13 @ Jun 30 2009, 11:50 AM)
I've got some machines using an ML1100 and others using ML1500 with NetENI. Both use a Hirschmann 5TX switch to join the panelview, plc, and connect to ethernet.
We tend to move lines and equipment around the building a lot. The cost of running ethernet drops or moving them gets expensive.
What do I need to get these on an existing wireless network?
Looks like you have some good answers to your root question so I'll digress to a tangent. Make sure you do a wireless survey before counting on wireless to connect your PLC to the network.
The average coverage circle of a WAP is 300 feet.
It can be even less when you factor in machine steel, catwalk steel and vessel walls.
Don't be surprised if at some point after going wireless you have to add/move a WAP to get the machine to connect.
I'd also advise you have contingency code in your PLC for what to do when comms fail.
