Full Version: PC Keyboard OPerations
Forums.MrPLC.com > PLCs and Supporting Devices > Omron
graemeian
I am using CX-One with a CH200HS. My project has a single button that I use for Diagnostics. However, I would like to quickly use more buttons. Is there a way to use the PC keyboard as input buttons while the PLC is in operation and I am in Monitor mode?
Thank you in advance.
Jay Anthony
Use Switchbox Utility - Start/OMRON/CX-One/Switchbox Utility
graemeian
QUOTE (Jay Anthony @ Jun 29 2009, 10:24 PM) *
I am trying Switchbox and I cannot get the software to monitor an address. Is there a help manual?
Also, I cannot use CX Programmer at the same time. DO I need a separate PC or a PC with multiple serial ports?
Thanks.
Doug
lostcontrol
QUOTE (graemeian @ Jul 31 2009, 10:18 AM) *
Thanks.
Doug
Why can you not use CX-Programmer? This would be the easiest way, and use a watch window, then you can monitor as much as you want...
graemeian
QUOTE (lostcontrol @ Jul 31 2009, 03:05 PM) *
Thanks.
Doug
Can I use assigned key(s) to mimic inputs to the PLC using CX-Programmer? For example, I have a timer sub for a heater and I would like to change the set value on a timer. I can do this with two switches using an algorithm to slowly increment the value. I would like to do this dynamically while in operation in a bench test using the keyboard.
Jay Anthony
Re: Switchbox:
Have you set the communication parameters to the same settings (i.e., baud rate,port,protocol, etc.)
Other Omron gurus:
Can this be done at the same time?
