Full Version: binary timer
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-Programmer
new_man
hiiii
for normal timer we write tim 1 #2. how can write instruction set for binary timer
pfort
QUOTE (new_man @ Jun 27 2009, 07:57 AM) *
hiiii
Hi,
In project workspace, right click on the PLC, then "Properties"
Depending on the PLC you have, you have the option "execute timer/counter as binary"
PMCR
For CP1L / CP1H / CJ1 / CJ2 / CS1, you can change all timers and counters to work as binary.
While offline, right click on your PLC (NewPLC1[CP1L]Offline an an example).
Select Properties.
Select Execute Timer/Counter as Binary.
Then use TIMX, CNTX instructions. The 'X' indicates binary format.
BITS N BYTES
NOTE:- You will still have to enter a prefix before each timer or counter preset value after changing PLC properties to "Select Execute Timer/Counter as Binary".
The preset value can be specified in either HEX or Binary.
For ALL timer/counter instructions with 'X' [except TIMLX(553)] set the preset value as follows:-
HEX with '#' prefix, range is #0 and #FFFF. Binary '&' prefix, range is &0 and &65535.
For TIMLX(553) only:-
HEX with '#' prefix, range is #0 and #FFFFFFFF. Binary '&' prefix, range is &0 &4294967294.
new_man
thaaaaaaanks thumbsupsmileyanim.gif thumbsupsmileyanim.gif thumbsupsmileyanim.gif yes.gif yes.gif yes.gif
