Hi,
We have received one alarm in our AB PLC (PLC-5 Processor 1785-L40C15)
'Adaptor # 3 Fault' and persisting in alarm page. In the Adapter # 3 (1794-ACNR15)all
the LEDs are healthy. (COM A&B, Status LED are green and steady)
Our system is redundant system, processor and all the IOs,
Node 3 is main and Node 4 is redundant.
After receiving this alarm some of the solenoid-operated valves are not operating
properly in auto sequence because the valve feed backs are not changing in the data table.
Toggle the signal from Ladder logic, valve is operating, feed back signals from the open
close limit switches are changing and verified in the Digital input module, field status is
matching but in the data file it is not changing.
ie. open condition open signal = 1 close signal also showing 1
but close condition close=1 and open=0
Is it Adapter fault or any other fault? Becoz the LEDs
Is it safe to change the Control net redundant adapter on line ?
Rest of the process is running well except the NODE 3 & 4
Kindly give your recommendations to solve this problem.
Thanks in advance.
Joy
