correct I have the enable the way you said.
I have P36 set to comm port
I have P38 set to 4 which I think should be a 5 ?
I am using the bits 12,13,14 to select the preset speed in parameters A071,A072,A073.
QUOTE (b_carlton @ Jun 26 2009, 02:31 PM)
Can you specify what you have tied to the control terminals. It sounds like you just have the terminal 1 input tied (either high or low) to the appropriate enable voltage (possibly through a contact? - which is fine).
In the setup you must specify that the control is coming from the communication, not from the front panel or from a terminal (P036). You may also be controlling the frequency from the communication which you must specify also (P038).Make sure the drive is stoped when making these parameter changes. As a general practice we cycle all power after these types of parameter changes.
