Full Version: WinCC Flexible 2008
Forums.MrPLC.com > PLCs and Supporting Devices > Siemens
Muhammad Daniyal
Dear All,
this is a very basic type of question, i am working on the wincc flexible n just hold down my work due to unawareness with software n this is my task to complete the job if you people help me i could continue with further.
1. how could we configure the object in the screen that if the boolean tag value set to high and the rectangle should fill green but not replace with green, and same tag value set to low the rectangle should fill with red but not replace with red.
2. if we draw a button with boolean tag, how could we configure the button if we press it will write "1" or depress it will write "0".
your guide will be valuable for me.
Regards
Muhammad Daniyal
GixRamones
Hi. with some way for both object.
1-------
1) declare Tag
2) draw obj
3)Go into panel property when the obj is select.
4)Look about animation (Visible, enabled, etc)
5)link here the tag
6)Select Type bool
2----------
Look also button property format of button
bye
