QUOTE (eccan @ Jun 24 2009, 05:47 PM)
Looking for an encoder to go with a Micrologix 1400. The encoder shaft will be turned by a shaft at 60 RPM and I need to know the shaft's location within .3 degrees. Does it matter what type of output the encoder has? Anyone have any brand recommendations (using a flange mount encoder)
Thanks
I've had good luck with BEI.
With 0.3 degrees, you're looking at 1200 ppr or more. If you want to know that number within +/-50%, then it doubles to 2400 ppr. The next higher "standard" (binary) size is 4096 ppr. Since you said shaft location but didn't specify if you can accept a "zero" function, then you'll need a 12 bit absolute encoder. If you can somehow zero/clear things or you can somehow introduce a timing mark then you could drop this to a quadrature encoder instead.
Either way at 60 RPM X 4096 PPR, you're looking at an input speed of 60 RPM / 60 secs/min = 1 rev/second, or 4096 pulses per second. At this relatively "slow" speed of only around 4 kHz, noise won't be a serious factor and you can probably get away with an open collector (push/pull) type non-differential input. However if you are even vaguely concerned about noise/interference, always go for the differential line driver. It is slightly more complicated to wire up but will reward you in the long run.
More important than the mechanical connection, consider the coupling you will be using, and also consider the physical connector. A lot of encoders use military style connectors, which are a real pain to put together. There aren't many out there but you can find a few with M12 type connectors and after going through the trouble of adopting military style connectors on a project last year, I'd use the M12 connectors even if it is a little harder to find the encoders and the cables.
As for brands, I had good luck with BEI. Allen Bradley encoders are actually rebranded Danaher (Dynapar)'s, which are also a good brand. I also had good luck with the units from Simpson Electric, but the resolution is way below what you need.
