QUOTE (sbaum @ May 29 2009, 04:50 PM)
I have recently upgraded a 8" and 12" NS V2 Screen to the latest Version 8.2.
After the update the NS Web Interface Monitor and Operation Screens display incorrectly ( See screenshot attached ).
Both screen are acting the same.
Has anybody else experienced this? I haven't changed the program, just simply converted it to v8.2. Everything was working
with v8.1.
You have probably downloaded v8.2 before it was removed from the downloads section. Reason of the removal is that Omron announced 2 faults in the firmware that needs to be fixed.
1. Web Interface will not work with Ver8.2.
2. Upload with USB/Serial / Ethernet will not work correctly. A file is missing.
I donj't know if this is your problem but I would downgrade the screen System Version to 8.1 which should be the same procedure as a normal upgrade. I would choose complete format of the screen memory.
