QUOTE (robh @ May 29 2009, 12:30 PM)
I wonder what the breaker panel looks like?
At the risk of a hijack, being that I too work as an industrial electrician, what are some of the most disgusting, gross, non code compliant, electricaly related things you have seen in an industrial facility? I will have to look for some pics.
First off, the beginning of the NEC book exempts certain things including air planes. On a plane, FAA rules are that ALL wires are white. They have to be stamped (and this is often not very easy) once every meter with a 5 digit wire number code. And wire fill rules don't apply. So usually some place along the spine of a plane, you'll have this massive wad perhaps 6-8 inches thick of hundreds of all white wires. It's the most disgusting, non code compliant thing I can think of.
Okay...but you said industrial...
Plant decided to use TFE instead of THHN because of the higher temperature specs. Apparently they didn't ever try to buy any color but RED. It's like working on an FAA project except you don't even have the labels on the wires every meter. Tracing was almost impossible, and prints were almost nonexistent.
Same plant, an electrician "spliced" a coaxial line with wire nuts.
Same plant, chief electrician had to replace the end of an Ethernet cable. So first he got out the box of RJ-45's and declared them all junk because they wouldn't fit in the socket (mind you, they had not been crimped yet). Then crimped on an RJ-11. Well, the old RJ-11 wouldn't stay in place so he simply jammed a small screw driver into the socket to keep that pesky RJ-11 in place and declared the Ethernet port on the industrial PC to be some cheap nonstandard "junk". Busted all the pins in the socket out in the process, and since the Ethernet port was integrated into the motherboard (mind you, a very expensive panel PC with a 19" touch screen), we ended up having to replace the whole motherboard on it at considerable cost. Needless to say, the electricians were laughing about this one for days, and photos and E-mails also made the rounds amongst the IT folks as well.
Same plant, chief electrician decided that they needed to tap another distribution cable into a fairly large 2.4kV splice. So he double-tapped it! It had three 500 MCM's on each phase. He took out a drill and drilled a hole and then inserted a one-hole lug with a bolt through it onto the termination to make up a "tap", running roughly 4/0 off to another area of the plant off the triple 500 MCM feeder.
Same plant, chief electrician decided to protect a fan cooled dry-type transformer from dust by sealing all the vent holes with lexan. Of course they knew they didn't want the transformer to overheat or anything and it couldn't "breathe" so they simply disconnected the cooling fans at the base of the coils.
Same plant, first day I started there, the chief electrician was "fixing" a PLC program by deleting whichever rungs he deemed weren't "working".
It was at least great water cooler material amongst other engineers and managers. We just never, ever knew what to expect next from this guy.
