Thanks for the info. I assume if I have a backup of the original I can download that to the PLC? Assuming that is the case is it possible to remove the password from the configuration somewhere before I put it back?
QUOTE(Steve Bailey @ May 21 2009, 03:00 PM) [snapback]82528[/snapback]
If you want to continue to use the existing program, the answer is no. There is no backdoor password.
If you only want to continue using the hardware, you can clear the memory and download a new program.
I have a 14 point Series 90 Micro in front of me, IC693UAA003, AC in relay out. I removed the plastic cover and then pulled off the top circuit board. That's the one with the six relays, eight SSRs, and all the LEDs. On the board below it, there is a big capacitor labeled CC5. Shorting that out should clear the memory.
