QUOTE(paulengr @ Apr 30 2009, 07:23 PM) [snapback]81711[/snapback]
For the record we were just discussing this in a large chemical plant a couple days ago. None of us has ever run into a memory limit on the L61. We've run into CPU limits (where you have to add a second CPU) but not a memory limit. The memory on an L61 is just so huge that it is not a problem.
Paul mentions lightly what I feel is a very good point. With Ethernet Communication, ControlNet Communication and DeviceNet Communication all occurring with your L61/L63 CPU it is very likely you'll approach what I call the "Operational Connection Count Limits" Please allow me to explain.
1. Every ControlLogix CPU communicates with communication controllers {ENBT, EWEB, CNB, DNB, DHRIO} thru the use of processors connections.
2. There is a hard limit {64,128,256} of the number of connections a CPU can have based on model and firmware. Read the manual for this number.
3. There is a soft limit or "Operational Connection Count Limit" which is somewhat less than the hard limit. Above the Operational Connection Count Limit your system is sluggish and communication is spotty or non existent on some occaisions. There are no hard and fast rules but the CPU and Comm Card manuals give you guidelines to figure these out. The experienced folks here can advise also if you post your plans in general terms. Card Counts, processors etc.
Hope this information is useful. it is worth considering. We have a mixing process which runs off 4 L63's for just this reason. One L61 can hold the code, but performance is unacceptable.
