QUOTE(nasir_ash @ Apr 25 2009, 10:53 AM) [snapback]81519[/snapback]
Dear Team
pls help me, hoe to configure the pid instruction for a fastest pid response.
pls also send me the values of the the parameters from P1----P7
awating for your reply
NASIR
There are no "magic" values.
I suggest you start with PIDAT instruction if available in your PLC, then make autotune. That will give you good parameters to start to work with. Then you can modify them to make yourresponse fastest, etc.
In the Omron manuel it is well explained how the P, I, and D parameters affects the the speed and overshoot.
