QUOTE(irah @ Apr 21 2009, 04:43 PM) [snapback]81348[/snapback]
Sorry for the delay. It was my day off yesterday. Ok its wierd. I tried inserting the modules 1 by one and downloaded the blank program for each one after IO configuration. No fault in any of them. CPU going to RUN. Then I put back all the modules, downloaded the original program. After I put in RUN mode, the CPU faulted and cleared itself twice (I'v read this is a self clearing fault). Then after this its working ok. Even tried running the machine. Its been 5 hrs and no fault yet. Is there any other procedure to know which slot is causing the problem incase it faults again?
Are one or more of the cards a 1746-OW8 if so see AB Knowledge base below:
QUOTE
1747 SLC 5/03 5/04 5/05 fault code 21h, no expansion I/O installed.
Question:
Getting 21h fault, expansion I/O remote power supply has failed on expansion rack. There is no external expansion rack installed.
Answer:
1746-OW8 output module in the local chassis is controlling inductive load.
Check suppression or replace module or both.
