QUOTE(Ken Roach @ Apr 17 2009, 06:20 PM) [snapback]81207[/snapback]
I'm not an SLC firmware author or RA tech support engineer, but I investigated closely the difference between FRN10 and FRN11 recently for a customer with a wireless Ethernet problem that he thinks might be the fault of the controller firmware.
I was told that FRN10 and FRN11 use the same firmware in the Ethernet daughtercard.
I tend not to believe that "the next firmware will fix the problem" unless the problem is identifiable and has a name or bug tracker number.
I am a bit skeptical myself but this problem didn't appear until after installing FRN10. I wouldn't have even installed FRN10 but I wanted a memory module and had to get my processor up to "spec" for it to take the module. If it is truly a bug, as stated by the Rockwell tech support, than I can only go by what they are telling me.
If I had known there was an FRN11 I would have purchased that along with the M13 and not FRN10, I wasn't told by Rockwell there was a more recent upgrade.
