Full Version: need a new HMI for an old Klockner Moeller PLC
Forums.MrPLC.com > PLCs and Supporting Devices > Other PLCs
Sasan
There is an old Klockner Moeller PS316 PLC (CPU-W: EBE 223.1 -5) with an electronic board as a text HMI (by using RS232 to RS485 converter). This HMI(Electronic Panel) is SYNTEC-Synatronic.
I'm going to replace this HMI by a new one, but I do't have the program of the PLC and HMI.
My question is:
1- Is there a touch screen HMI that can be connected to this PLC easily?
2- How can I find the addresses of those PLC flags that used in HMI?
Thanks, Sasan
Sasan
Hi,
I need help,
Please.....
ndzied1
QUOTE(Sasan @ Apr 12 2009, 09:06 AM) [snapback]80985[/snapback]
Hi,
I need help,
Please.....
Micro Innovation makes HMI's that will talk to the Moeller PLC.
http://www.microinnovation.com
I believe they are partially owned by Moeller.
The problem is going to be finding the tags/addresses that the system is using. You cannot upload the program out of these PLC's. You should try to find out more about the existing HMI and see if you can get the configuration from that device.
You might try to call Moeller or Micro Innovation to see if they can help you.
