Full Version: Intermittent Connection via Hostlinl
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-Programmer
denise01
Hi,
I have a problem with my connection via Hostlink that I use in order to monitor Supervisor on one of our production lines. there are 3 CJ1M plcs connected to the end of line PC using AL001 Inerface connector and a CIF 11 in each plc the problem is that 2 of the plcs connect okay but the 3rd keeps losing its connection. it will stay on if I connect via rs232 on the laptop. I have changed the plcs CIF 11 but thre problem is still there. I have assigned unit numbers to the 3 plcs, cant understand howit can connect and then disconnect.
Peter
Sleepy Wombat
two things come to mind
1. bad connection
2. Interference.. what type of cable are you using between the PLC's.
