Full Version: FINS problem
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > Other Omron Software
LPG
Hi to all,
I have a little problem when I try to connect via FINS comand to a PLC
I'm using a Sysmac CJ1M CPU12 unit and ETN21 unit in a new plant project.
I've configured the Ethernet unit with an IP address and I've connected ok to PLC via Ethernet.
The node address in the unit is set to 8
The proyect (CDM) connects ok with this node without errors.
The problem appears when I've tried to read with a FINS application from a VB6 program.
I've received a "Directory not empty (FINS error 0 x 2108)." and is impossible to read anything.
I have 3 more PLC's in other network and I haven't any problem with them.
Please can anyone advise me?
Regards
Paco
PMCR
Can you post some screen shots or copy / paste of the FINS command that you are sending, and the response.
The full FINS command and the full response would be the most helpful.
LPG
Hi, (I was on holidays)
The problem is not the comand, because I send this command to the other PLC's and I receceive a good response.
I tried the simplest 0501 command.
This is th first PLC that I've install. The others were installed yet.
Curiossly I test the FINS connection with CX one Network utility without problem. Only from the VB test program is wrong.
Thank you for your interest.
LPG
Hi again
I left a screenshot, using UDP utility...
PMCR
I have a few questions:
Can you show a screen shot of the configuration of the Ethernet/IP module?
Can you show the firmware version of the ETN21? (In the IO Table of CX Programmer, right click on the module and select 'Unit Manufacturing Information').
What subnet mask are you using for the PC and PLC?
If you can provide this information, I can help.
LPG
Hi PCMR,
Thank you for your time...
I've attached too the CX-Net screen with the PLC connected
One tip:
Conversion is showing marked the option IP addres table but in PLC I have the first option (Automatic - Dynamic)
PMCR
I am confused as to why this does not work.
One thing that I can tell you is that in the FINS utility, the Source UDP port may not be correct. The original author (a colleague of mine) did not actually change the source UDP port in the VB code. Possibly you have changed it. So, it shows 9610, but really uses 9600.
I cannot reproduce the problem. I am using the same UDP FINS VB code, an ETN21 with the same firmware version. (There are no problems with different firmwares, but older firmware did not support different UDP ports at PC and PLC).
Can you double check the setup in the PLC ethernet card?
In your VB screen shot, you show the PC sending FINS commands as node 03. Normally in FINS Ethernet, we use the last octet of the IP for the node. What happens if you type 79 as the FINS Node for the PC? This is the HEX of 121. Is another node on the network FINS Node 3?
PdL
Just a shot in the dark; could it be the CPU has an invalid routing setting for the ETN21?
PMCR
PDL
Good thought, but I don't think it will be a routing table issue.
The UDP FINS command is from Net 0 to Net 0.
0 = 'local' in the word of Omron.
Even if there is a routing table, and the ETN21 is not in it, it should respond to net 0.
PdL
QUOTE(PMCR @ Apr 14 2009, 10:07 PM) [snapback]81057[/snapback]
PDL
PMCR
I still think that the key is in the module setup.
PdL
LPG, you could save a lot of screenshots posting by saving the IO table setup file for the ETN21, right click in IO table and select "save parameters". Now post the file zipped and we can all review the settings.
LPG
Good Morning,
PCMR, I've used by two years UDP utility to check and test the PLC's in the plant. Is a good tool, and I've made many programs based in it, that read and write data in those PLC's. Is the first time that I found one problem like this.
Checking the error registry in teh unit I've found this (screenshot)
I've attach the configuration file for ETN module. But I only see "garbage" in it (jeje).
I post a screenshot that show the answer from a running PLC.
PdL
QUOTE(LPG @ Apr 15 2009, 09:37 AM) [snapback]81073[/snapback]
When you open it in explorer, yes. But in the IO table you can load the paramters with the "load parameter" option the same way you save them wink.gif
PMCR
LPG.
I setup the network exactly as shown by LPG.
Same IP, same subnet, etc.
I was able to reproduce the problem, and determine the solution.
The solution is to allow dynamic changes to the IP address of the PC as shown below in the ETN21 setup.
The 2 screen shots are basically the same information for version 1.3 and 1.4 ETN21 modules.
If the 'Change to Dynamic' option is not on, the ETN21 module will only respond to IP / FINS Nodes that are listed in the FINS to IP conversion table. As your table was blank, the ETN21 would not recognize the command as valid from a valid IP and FINS Node.
So, you could leave 'Change to Dynamic' unchecked, but then you must list the PC in the FINS to IP conversion table.
[attachmentid=7411]
PdL
LPG
Is incredible but this is the solution. I was stuck for a days.
Really I don't know why this was selected, and why I don't change it... ¿?
I was only looking for the FINS error 2108, argggg.
You save me...
Thank you for all
Jay Anthony
