I've got a basic understanding of how a single PID loop works, but I'm getting a little confused on cascaded loops. The way I understand it the minor loop should be the loop that responds quicker? My application is a heater and oven setup. I have a thermocoupler in each, an UDC (Honeywell controller) for the high limit and need to limit the heater to no higher than 1100 F and the oven to 850 F max. This is with a DL06 fitted with F0-04THM and F0-04AH-1.
So my understanding is that the PV's would be the themo inputs, the minor loop would be the heater and the major the oven, SP for the oven would be 850 F max (user input from a touch screen).
So since the SP is ignored in the minor loop, how do you limit it to under 1100 F? Where have I strayed? If it sounds confusing, it's because I am.
Mike
