Full Version: Is there such a thing as small CoDeSys PLC?
Forums.MrPLC.com > PLCs and Supporting Devices > CoDeSys
Veganic
What is the smallest PLC platform that is available on the CoDeSys platform?
Is there anything equivalent to a 'brick' plc?
BITS N BYTES
The closest thing that I have seen to a brick style PLC with CoDeSys is the Rexroth Indralogic L10.
http://www.boschrexroth.com/business_units...CFQa-sgodIU_otg
There may be others!!
Veganic
QUOTE(BITS N BYTES @ Mar 27 2009, 05:18 AM) [snapback]80421[/snapback]
How do prices compare to a 'brick'?
I'm guessing that's at least £500s worth?
Nick Clute
I've only ever used the Turck Programmable gateways, they come in both inside the panel and outside the panel versions, both modular IO systems. They are the BL67 and the BL20. Lists in the US for around £420...
cadomanis
Check out the Beckhoff BC9100. Uses their TwinCat software which is essentially the same as CoDeSys. Base is around $300US and you can add what ever IO you need. Has ethernet built in!!
Veganic
Thanks
ndzied1
I believe this is what you are looking for:
http://trainingscenter.moeller.net/products/easyControl.html
Veganic
QUOTE(ndzied1 @ Apr 7 2009, 06:47 AM) [snapback]80818[/snapback]
Interesting.
Thanks.
suby
Look at this:
http://www.abb.com/product/ap/seitp329/cf4...de0030b6b4.aspx
I think that this is the closest brick PLC.
It's price is around 200 € for a bare PLC.
