Full Version: timer delay
Forums.MrPLC.com > PLCs and Supporting Devices > Modicon
sal7
Hi,
What im trying to do is put a timer on delay between a memory flag coming on and output to a memory word. Can this is been done in twido soft and if so how so??
Regards,
sal
Oh i forgot to mention also that i have several lines in this rung and i did try and fit a timer in there.
regards,
Sal
aggattapauer
QUOTE
shift + F9
The %TM object could stay only in the first line of a rung. If you already have programmed a rung and you need to add a delay you have to re-build the rung or create a new rung with the programmed timer linked to the previous rung with a flag.
It's hard to me to explain.. you might send me an example so I could show you some solution.
sal7
QUOTE(aggattapauer @ Mar 16 2009, 08:41 PM) [snapback]79992[/snapback]
QUOTE
shift + F9
No i got what you are tyring to say, I am trying to do that at the moment. Ill work on it some more and if i have no joy ill post an example of what im trying to do.
Thanks,
Sal
