QUOTE(paulengr @ Mar 2 2009, 11:41 AM) [snapback]79487[/snapback]
QUOTE(Ron Beaufort @ Mar 2 2009, 01:24 PM) [snapback]79485[/snapback]
pull the battery ... count to 10 or so ... that should kill it back to "off the shelf" conditions ...
possible exception: you MIGHT have an EEPROM memory module installed ... if so, pull that too - and ask for advice before you put it back again ...
There's a capacitor on the PLC-5 to allow you to maintain the program during battery changes. Power down the rack. Pull the battery. Short the connections on the battery connector. Then reinstall the battery and you're good to go. And yes if you have an EEPROM module, pull that too.
I pulled the battery and took a short lunch. Came back, and it is taking the download now. Looks like it is working. thanks guys.
